2025
View new features for Altair HyperWorks 2025.
Learn how to access and download required model files.
Tutorial Level: Beginner In this tutorial, you will create and edit curves and plots.
Tutorial Level: Intermediate In this tutorial, you will learn how to create bar charts by entering values, importing a data file, or specifying a mathematical expression.
Tutorial Level: Beginner In this tutorial, you will learn how to create complex plots from a data file and add and edit complex data curves by using mathematical functions.
Tutorial Level: Beginner In this tutorial, you will learn how to create polar plots from a data file and add polar plots by using mathematical functions.
Tutorial Level: Advanced In this tutorial, you will learn how to customize the program using the preference file.
Tutorial Level: Intermediate In this tutorial, you will learn how to create surface plots.
Tutorial Level: Intermediate In this tutorial, you will learn how to work with the Axes panel, edit curve attributes, contour line plots, and use the Edit Legend dialog.
Tutorial Level: Intermediate In this tutorial, you will learn how to query data from the surface plot and create and use datum planes.
The Developer ribbon contains tools for automation and customization.
