Browser Preferences
Define browser preferences.
From the File menu, select to define the following browser preferences.
- Appearance
- Left justify numeric fields
- Left justifies the numeric fields in the Entity Editor.
- Right justify numeric fields in Card-Editor
- Right justifies the numeric fields in the Card Editor.
- Organization
- Show entities in model and subsystem browsers
- Shows the entities under sub-folders in the Model Browser and Subsystem Browser.
- Show keyword level under elements folder
- Shows the keyword level under the elements folder in the Model Browser, include, and Subsystem Browser.
- Limit Entity Populations
- Enter a value to change the limit for the entity populations in browsers.
- Selection
- Autofit graphics
- Automatically sizes graphics to fit inside the modeling window when performing Show/Hide/Isolate from graphics or a browser.
- Autoscroll browser
- Automatically scrolls the browser to the selection when an entity is selected graphically.
- Autosort
- Automatically sorts the entities in the currently applied sorting (Name, ID, and so on) upon creating and editing entities.
- Live filtering
- Enables live filtering of entities upon data modification with a filter applied.
- Tree lines
- Displays line connections between folders and entities in the hierarchy tree.
- Show nested entities on filtering
- Facilitates the listing of nested entities when a top-level entity is filtered. For example, when an include file is found as the result of a filter, all of its nested content is shown.
- Invoke browser on double-click in graphics
- Invokes the respective browser upon double-clicking an entity in graphics.
- Sync idle selector and active browser
- Always: Sets the idle selector to the respective entity upon switching to a browser, and sets the active browser to the respective view upon setting an entity type in the idle selector.
- Block review
- Sets the entity type that the block entity will review based on when the block entity contains multiple entity types.
- Limit for populating entity editor for idle selections
- Limit for populating the Entity Editor for selections made in the idle selector.
- Selection Search
- Max suggestions Name
- Maximum number of result suggestions for name matches.
- Max suggestions ID
- Maximum number of result suggestions for ID matches.
- Match exact phrase
- Treats the spaces as characters instead of a search term separator.
