Clear the Access Limit for a User
You can remove the set access limit for a user.
- Click .
Click the Clear Limit button.
The Clear User Access Limit dialog box is displayed.
Figure 1. Clear User Access Limit
- Select the user's email address from the drop down list.
- Select the License ID under which the access limit was set for the user.
Click Submit.
The license limit is removed for the user.
