Manage Favorites
Create and maintain different lists of favorite materials to quickly access from the catalog or maintain a list of materials for your project.
Use your favorite materials to save, clear, load the saved favorites list, share the link to the favorite materials lists using clipboard or email and also add your favorite materials to compare.
  1. Hover over a material and click Favorite () to add it to the list of favorite materials.
    The material is marked as a favorite and is represented with a star .
    Note: To remove material from favorites, click the solid star () of a material.
  2. To view all your favorite materials, click Favorites.
    Figure 1. Materials added to Favorites
  3. Click the drop-down arrow menu next to Favorites and select Save Favorites.
    Figure 2. Save Favorites
    Save Favorites
  4. Enter a name and save your favorite materials.
    Note: Click Clear Favorites to remove the unsaved favorite materials from the Favorites list.
  5. Click the drop-down arrow menu > Load Favorites to select and view your saved materials list.
    Figure 3. Load Saved Favorite Materials
  6. Click the drop-down arrow menu > Share Favorites > > Copy to Clipboard to share your favorite materials link from the clipboard or select Send via Email to share the link through email.
  7. Click the drop-down arrow menu next to Favorites and select Add to Compare. The favorite materials are added to a comparison list.
  8. Click Compare to compare the selected materials data.
    Figure 4. Compare Favorite Materials
    Note: You can select up to ten materials to compare the material data.
