These options define how the material data displays or functions.
You can view
the entire material database and skip the SMDC landing
page by selecting the Skip Landing Page check
box.
Click Preferences from the action ribbon.
Figure 1. Select Preferences The Preferences dialog box is displayed.
Choose the language from the Select Language list
box.
Figure 2. Set the required Preferences
Choose the unit system from the Select Unit System list
box.
Figure 3. Unit System Preferences
Choose the required theme to set it for the application from the
Theme list box.
Figure 4. Theme Preferences
Select Use default sort. It displays materials in the
database with the most complete data first.
Select the Skip Landing Page check box to skip the
landing page every time you log into the SMDC
application.
Fill Data Gaps is an integrated tool that can fill gaps in the material
data when required. This will improve the usability of the material and making
it applicable to multiple simulations types.
Select Generic data to predict the missing
product data using the identical trade products data
Select Artificial Intelligence to predict the
missing curve data using artificial intelligence.
Click Apply.
The browser refreshes to display the set preferences.
