Manage Subsystem Revisions
Manage, control, and update Major, Study, and Library subsystem revisions using the Subsystem Library.
About Subsystem Library and Revisions
The Subsystem Library is an integral part of data management and revision control within the Subsystem Browser.
The Subsystem Library serves as a centralized library of HyperMesh subsystems, which in turn facilitates the collaboration between simulation teams. You must be connected to a subsystem library to access all subsystem library related options.
Revisions
In the Subsystem Browser, the Revision column displays the Major revision, Study revision, and Library revision. All appropriate workflows have entry or access points to the subsystem library, enabling quick and easy access to previous revisions or simply generating new revisions.
You can review the following revisions in the Entity Editor:
Major Revision
Depicts a change or set of changes that have been finalized and released for further review. In most cases the Major Revision should be mapped to the PDM Revision, but you can modify it.
Study Revision
Created locally to track experimental changes or prototyping changes that may or may not be published. The purpose of the Study Revision is to manage design and prototype exploratory concepts. You can modify the Study Revision.
Library Revision
Locally, published revision within the Subsystem Library. You cannot modify the Library Subsystem Revision. It automatically increments on each save when major and study revision are not changed
Create, Add, and Connect to Libraries
Create, add, and connect to libraries.
For more information refer to Manage Part Revisions.
Sync Library Revisions
Sync the in-session library revision with the latest available revision in the Substation Library.
If someone else has made changes to the library and your session is not up-to-date with the library, use Sync to recheck the library for the latest data, making the latest library revision available the next time a user loads from the library.
Before you can sync library revisions, you must Create and Connect to Libraries.
In the Subsystem Browser, right-click on a subsystem and select Library > Sync from the context menu.
