DOPTPRM, GEOMSENS
Bulk Data Entry Activates geometric sensitivity influence in topography or free shape optimization.
| Parameter | Values | Description |
| GEOMSENS | <YES, NO> |
Note: ERP and SPL responses are directly related to the geometry of
the structure. However, the sensitivity calculation ignores the
contribution from geometry change by default, because the
computation cost would be too high. Such influence to the
sensitivity could be big in free shape optimization and could be
activated via this parameter if the run time is
acceptable.
