Run Dynamic Domain
This section explains how to run Dynamic Domain from the command line.
To run EDEM Dynamic Domain from the command line:
- Use the flag
“--dyn”followed by the number 0 or 1.--dyn 0disables Dynamic domain--dyn 1enables Dynamic domain
- Dynamic Domain runs with the following default values:
- Check interval: 0.1
- Number of checks: 3
- Particle displacement: 10% of Rmin
You can specify the Check interval, Number of checks, and Particle displacement values with the flags defined in the processing flags table.
Exampleedem.exe --console -i simulation_deck.dem -p 4 -r 2 -w 0.1 –g 4 -t 1e-6 --dyn 1 –-dyn-interval 0.15 –-dyn-check 4 –-dyn-disp 15This will use Dynamic Domain with the following values:- Check interval: 0.15s
- Number of checks: 4
- Particle displacement: 15% of Rmin
