Data Export Options
In any EDEM simulation, you configure the export data settings in EDEM Analyst.
If you have a series of simulations with the same data export options required, only
one simulation needs to be set up with the required queries. These queries are saved
in the simulation_name.dfg file that you can copy or rename.
When using the -e flag, it is not mandatory for the
.dfg file to have the same name as the .dem
flag:
edem.exe -–console –i “input1.dem” -e “export_queries.dfg”
edem.exe -–console –i “input2.dem” -e “export_queries.dfg”
edem.exe -–console –i “input3.dem” -e “export_queries.dfg”
Note: Since the previously defined data from the three simulations
is exported with the same file name (for example,
results.csv), it
is recommended to rename the results file after each simulation.edem.exe -–console –i “input1.dem” -e “export_queries.dfg”
rename results.csv results1.csv
rename results.csv results2.csv
rename results.csv results3.csv
