Replace Geometry from the Command Line
The Replace Geometry command requires a configuration file that contains relevant information for each Geometry which is being replaced.
The format of this file is as follows:For each section to be replaced, include a
line formatted where the delimiter is the '#'
character:
<cfg file section> # <target section name> # <CAD file> # <import units> # <Geometry material> # <mesh (y/n)> # <Min Size/Element Size> # <Max Size> # <Max Deviation> # <Max Angle>- If you use the meshing option n, the default mesh import options will be used.
- If you use the meshing option y, the number of arguments after the
y will determine the approach used. A single value will use the Size
and Bias approach, and four values will use the Rigid Body approach.
Thecfgfile section is a unique identifier for each object. You can assign any value provided that it is unique to any othercfgfile section used in the file.Section1 # guide 1 # D:\Wall21.stl # m # steel # n Geometry will be imported using default mesh optionsSection2 # guide 2 # D:\Wall22.stl # mm # steel # y # 10 Geometry will be imported using size and bias approach and Element size 10mmSection3 # guide 3 # D:\Wall23.stl # mm # steel # y # 10 # 100 # 1 # 15 The Geometry will be imported using the Rigid Body approach and the four parameters shown - Reference the
configfile from the command line as follows:edem.exe --console -i td.dem --rg rgconfig.txt -R
