Quantity computation on points: add a formula
Add a formula
Now the user can add a formula in an already existing session of computation on points.
| Step | Action |
| 1 |
Open the dialogue box corresponding to the command Add a formula:
| → | The dialogue box Add formula will appear |
| 2 | Choose the desired quantity (1st column) |
| → | The list of components corresponding to the selected quantity will appear in the 2nd column |
| 3 |
Choose one or more desired components:
| → | The formulas « Flux » corresponding to the selected components will appear in the 3rd column |
| 4 | Validate by clicking on OK |
Note: The user always has the possibility to add his own formula (if it has not been
proposed) starting from the formula editor by clicking on
Certain limitations
- In the dialogue box Add formula, the quantities already taken into consideration in this calculation entity will not appear.
- Adding of a formula is only possible if the calculation on a point session is closed.
