Quantity computation on points: open / close a session
Open a session
To open a current point computation session:
| Step | Action |
| 1 | Activate the command Open a session (see image) |
| → | The computation session is open. |
| 2 | Consult the computed values in the table of results |
To open the session directly:
- in the data tree double-click on the entity of point computation.
Note: To open a contextual menu, use the right button of the mouse.
Close the session
To close the current point computation session:
| Step | Action |
| 1 | Activate the command Close a session (see image) |
| → | The computation session is closed. |
