Open File
This function opens the file for reading. This function returns (1) if the file is found and opened or else (0).C Calling Sequence
int c_rto_open_file(const char *fName);
Arguments
| Argument | Type | Description | |
| fName | Character Array | Input | File path |
FORTRAN Calling Sequence:
LLFUNC void STDCALL RTO_OPEN_FILE_F2C(char *CHTDST, int dummylen, int *NCHTDS, int
*RETURN_VAL)
Arguments
| CHTDST | Character Array | Input | File path |
| NCHTDS | Integer | Input | The number of characters in the FileName. |
| RETURN_VAL | Integer | Output | If file is found and opened then it returns 1 or else. |
Note: Before using any of the other RTO utilities, you must first open a file using this
subroutine.
