Components Library
Component models share the
following features:
- Components are ready to be connected in the model with no additional modeling requirements.
- Predefined outputs are included covering most of the components desired results.
- Parameters can be included in MotionView or accessed through a property file (TeimOrbit) independent of the MotionView mdl and MotionSolve input deck.
| Entity | Function | Features |
| Air Spring |
| Helical Spring |
| Shock Absorber |
Dissipate the energy stored in springs and damp the chassis motions |
| Mount Bushing |
Elastically mount vehicle components to the vehicle chassis or body |
| Frequency Dependent Bushing |
| Bump Stop |
Limit suspension bump travel |
| Rebound Stop |
Limit suspension rebound travel |
| Rider |
Model the mass and inertia of a vehicle driver and passengers |
| Tire |
