Create and Edit Arc Lines
Use the Arc Lines tool to create arcs for geometry construction, edit free arcs, and create/toggle filled arcs.
New arcs are organized in the same component as the entity where the center point is placed.
When there is ambiguity, the Arc Lines tool switches between possible inferred normals.
From the Topology ribbon, Shapes tool group, click the Arc Lines tool.
Draw an arc in on of the following ways:
- Click to place the center then drag and click to define the radius and arc angle.
- Hold Ctrl and click to draw an arc with three diametric points.
Tip: Press Tab to alternate orientations. -
Modify the size and location of the arc in the following ways:
- Edit the radius and angle values in the microdialog and press Enter.
- Click
to translate and rotate the
arc using the Move tool. - Click
to fill the shape.
- Click
to imprint lines.
- Double-click on an arc to edit its dimensions.
Tip: Use snap points to snap
to pre-defined points on your model such as end, middle, center, and intersection
points.
