Supported Entities
Entities supported by the
OCX reader.
- Vessel
- Arrangements
- Compartments
- Physical spaces
- Panels
- Plates
- Pillars
- Stiffeners
- Brackets
- Hole profiles
- Seam profiles
- Reference planes
When
@CreationType =
TreeOfComponents, an
assembly tree is created and organized as follows:
- 1 assembly corresponding to a vessel
- 1 assembly per arrangement
- 1 component per compartment
- 1 component per physical space
- 1 component per vessel level plate
- 1 component per vessel level bracket
- 1 component per vessel level stiffener
- 1 component per vessel level pillar
- 1 assembly per panel
- 1 component for the geometry of the panel
- 1 component per panel level plate (if XXXX
option is enabled)
- 1 component per panel level bracket
- 1 component per panel level stiffener
- 1 component per panel level seam
- 1 component per panel level pillar
When @CreationType = Parts, a corresponding tree
is created but not assembly entities are created. Parts are created instead. The
components are also created.
When @CreationType = BOM Only, a corresponding
tree is created with parts as in the previous case, but no components are actually
created.
Panel geometries, plates, and brackets are mapped onto surfaces. Stiffeners and
pillars are mapped onto curves, but can be mapped onto surfaces if the option
XXXX is enabled and the corresponding info can be found in the
file. Seams are mapped into curves.
Appropriate material definitions are also created in the model. Supported material
info includes density, Poisson’s ratio, thermal expansion, ultimate stress, yield
stress, and Young's modulus provided as metadata of the material. Each material is
associated with a unique grade name. Objects reference material entities via
metadata. Thickness info is provided as metadata of plate parts.
Beam section definitions are also created in the model. Stiffeners using a beam
section reference definitions via metadata.
Import Options
The
OCX reader uses the
ocx_reader.ini file.
@BodyIdAsMetadata
| Value |
Description |
on |
Assign body identifier as
metadata. BODY_ID
off |
Do not assign body identifier as metadata (default). |
@CleanupTol
| Value |
Description |
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value
greater than the calculated auto cleanup tolerance indicates to use that specific
tolerance. Refer to the CAD Import Options. |
@CreateComposingPlates
| Value |
Description |
on |
Create geometry for panel level plates. |
off |
Do not create geometry for panel level plates (default). |
@CreateDetailedObjects
| Value |
Description |
on |
Provide a more complete representation of an object when available
(default) |
off |
Provide just the basic representation of an object. |
@CreateObjectContours
| Value |
Description |
on |
Create a wire frame representation of the object contours. |
off |
Do not create a wire frame representation of the object contours
(default). |
@CreationType
| Value |
Description |
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
@DoNotMergeEdges
| Value |
Description |
on |
Preserve the original geometry edges, instead of merging them together during
the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
@ExtendSurfaces
| Value |
Description |
on |
The imported surfaces are extended to match neighbor surfaces
(default). |
off |
The imported surfaces are not extended. |
@ImportCompartments
| Value |
Description |
on |
Import both compartments in the IGES files, and
compartments defined by “Faces”. The former by importing the geometry, the latter
just by creating a metadata; also reference planes are created, because they can be
referenced by compartments. |
off |
Do not import any compartments (default). |
@ImportHoles
| Value |
Description |
on |
Create holes (default). |
off |
Do not create create holes. |
@LegacyHierarchyAsMetadata
| Value |
Description |
on |
Generate metadata with the original CAD hierarchy within the
part. LEGACY_HIERARCHY
off |
Do not generate metadata with the original CAD hierarchy within the part
(default). |
@MetadataPrefix
| Value |
Description |
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming
for more details. |
@OrphanPlatesAsSurfaces
| Value |
Description |
Surfaces |
When a vessel level plate contains just wire frame, create appropriate surfaces
out of it (default). |
Any other value |
Keep wire frame representation only. |
@ScaleFactor
| Value |
Description |
double |
Define the model scaling factor during import. Default is 1.0. |
@SplitComponents
| Value |
Description |
Part |
Generate part-based component (only allowed value if
CreationType=Parts). |
General |
Keep component as in CAD (only allowed value if
CreationType=TreeOfComponents). |
@StitchEdges
| Value |
Description |
on |
Edges of close surfaces are stitched together (default). |
off |
Edges of close surfaces are not stitched together. |
@TargetUnits
| Value |
Description |
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting
legacy scripts). |
Supported Metadata
Metadata possibly generated from the
OCX reader.
AirFillingHeight
| Type |
Entities |
Description |
double |
components if hierarchy as Assemblies; parts if hierarchy as Parts |
Compartments and Physical Spaces might contain this metadata if available in
the OCX file. |
AirPipeHeight
| Type |
Entities |
Description |
double |
the OCX file. |
AP_Pos
| Type |
Entities |
Description |
double |
assemblies if hierarchy as Assemblies; parts if hierarchy as Parts |
Vessels might contain this metadata if available in the OCX file. |
BEAM_SECTION
| Type |
Entities |
Description |
entity |
parts |
Stiffener groups might contain this metadata which points the corresponding
BEAMSECTION entity. |
BlockCoefficient
| Type |
Entities |
Description |
double |
BulkCargoAngleOfRepose
| Type |
Entities |
Description |
double |
the OCX file. |
BulkCargoPermeability
| Type |
Entities |
Description |
double |
the OCX file. |
BulkCargoStowageFactor
| Type |
Entities |
Description |
double |
the OCX file. |
BulkCargoType
| Type |
Entities |
Description |
string |
the OCX file. |
CallSign
| Type |
Entities |
Description |
string |
COG_X
| Type |
Entities |
Description |
double |
X position of the center of gravity for panels, plates, stiffeners, brackets,
pillars, compartments, physical spaces. |
COG_Y
| Type |
Entities |
Description |
double |
Y position of the center of gravity for panels, plates, stiffeners, brackets,
COG_Z
| Type |
Entities |
Description |
double |
Z position of the center of gravity for panels, plates, stiffeners, brackets,
DeadWeight
| Type |
Entities |
Description |
double |
DeepestEquilibriumWL
| Type |
Entities |
Description |
double |
| Type |
Entities |
Description |
string |
assemblies or components if hierarchy as Assemblies; parts if hierarchy as
Parts |
Contains the description of an object as provided in the OCX file. |
Designer
| Type |
Entities |
Description |
string |
DesignSpeed
| Type |
Entities |
Description |
double |
DryWeight
| Type |
Entities |
Description |
double |
Parts |
Panels, plates, stiffeners, brackets, pillars might contain this metadata if
ExternalGeometryFormat
| Type |
Entities |
Description |
string |
the OCX file. |
ExternalGeometryReference
| Type |
Entities |
Description |
string |
the OCX file. |
FlagState
| Type |
Entities |
Description |
string |
FlangeDirection
| Type |
Entities |
Description |
double array |
An array of six double values might be added to each line belonging to
stiffeners and pillars. Each line is provided with two triplets of inclination
values to form two unit vectors. The vectors indicate the inclinations of the
flange, if any, at the endpoints of the lines in the absolute reference
system. |
FP_Pos
| Type |
Entities |
Description |
double |
FreeboardDeckHeight
| Type |
Entities |
Description |
double |
FreeboardLength
| Type |
Entities |
Description |
double |
FreeboardType
| Type |
Entities |
Description |
string |
HasBilgeKeel
| Type |
Entities |
Description |
string |
HasDeadWeightLessThan
| Type |
Entities |
Description |
string |
HeavyBallastDraught
| Type |
Entities |
Description |
double |
Identification
| Type |
Entities |
Description |
string |
INCLINATION
| Type |
Entities |
Description |
double array |
assems |
An array of 6 double values is added to each line belonging to pillars,
flanges, stiffeners, and faceplates. Each line is provided with two triplets of
inclination values to form 2 unit vectors. The vectors indicate the inclinations at
the endpoints of the lines in the absolute reference system. |
LengthOfWaterline
| Type |
Entities |
Description |
double |
assems if hierarchy as Assemblies; parts if heirarchy as Parts |
Lpp
| Type |
Entities |
Description |
double |
Material
| Type |
Entities |
Description |
entity |
parts |
Plates, brackets, stiffeners and pillars might contain this metadata which
points the corresponding MATERIAL entity. |
MODELUNIT
| Type |
Entities |
Description |
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts |
Model units specified in the CAD file.
- 1 = inches
- 2 = millimeters
- 4 = feet
- 5 = miles
- 6 = meters
- 7 = kilometers
- 8 = mils
- 9 = microns
- 10 = centimeters
- 11 = microinches
- 12 = decimeters
- 13 = yards
This is always generated. |
MouldedBreadth
| Type |
Entities |
Description |
double |
MouldedDepth
| Type |
Entities |
Description |
double |
MouldedDraught
| Type |
Entities |
Description |
double |
NewBuildingSociety
| Type |
Entities |
Description |
string |
NewBuildingSocietyName
| Type |
Entities |
Description |
string |
NormalBallastDraught
| Type |
Entities |
Description |
double |
NumberIMO
| Type |
Entities |
Description |
string |
NumberOfDecksAbove
| Type |
Entities |
Description |
string |
OCXObjectType
| Type |
Entities |
Description |
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts |
The value is a string indicating the role of the object. Currently created
values include:
- Vessel Container
- Vessel
- Panel
- Plate
- Stiffener
- Bracket
- Pillar
- Arrangement
- Compartment
- Physical Space
- Panel Geometry
- Seam
OFFSET
| Type |
Entities |
Description |
double |
Plates and brackets might contain this metadata if available in the OCX
file. |
Owner
| Type |
Entities |
Description |
string |
Plate_T
| Type |
Entities |
Description |
double |
Plates, stiffeners, brackets and pillars might contain this metadata if
PortRegistration
| Type |
Entities |
Description |
string |
Purpose
| Type |
Entities |
Description |
string |
the OCX file. |
ReliefValvePressure
| Type |
Entities |
Description |
double |
the OCX file. . |
RuleLength
| Type |
Entities |
Description |
double |
ShipName
| Type |
Entities |
Description |
string |
ShipType
| Type |
Entities |
Description |
string |
SlammingDraughtEmptyFP
| Type |
Entities |
Description |
double |
SlammingDraughtFullFP
| Type |
Entities |
Description |
double |
Society
| Type |
Entities |
Description |
string |
SocietyName
| Type |
Entities |
Description |
string |
SpeedFactor
| Type |
Entities |
Description |
double |
Tightness
| Type |
Entities |
Description |
string |
Panels might contain this metadata if available in the OCX file. |
Tonnage
| Type |
Entities |
Description |
double |
UnitCargoType
| Type |
Entities |
Description |
string |
the OCX file. |
UpperDeckArea
| Type |
Entities |
Description |
double |
Volume
| Type |
Entities |
Description |
double |
the OCX file. |
WaterPlaneArea
| Type |
Entities |
Description |
double |
Yard
| Type |
Entities |
Description |
string |
YearOfBuild
| Type |
Entities |
Description |
string |
ZPosDeckline
| Type |
Entities |
Description |
double |
ZPosOfDeck
| Type |
Entities |
Description |
double |
