Supported Entities
Entities supported by the
AVEVA Marine reader.
- Plane panels
- Curved panels
- Knuckled panels
- Plane plates
- Curved plates
- Pillars
- Stiffeners (also with sub-flanges)
- Curved stiffeners
- Face plates (also with sub-flanges)
- Flanges
- Brackets
- Doubling profiles
- Hole profiles
- Marking profiles
- Seam profiles
- Swage profiles
- Tap profiles
When
@CreationType =
TreeOfComponents, an assembly
tree is created and organized as follows:
- 1 assembly corresponding to the whole ship (1 ship per part).
- 1 assembly per block.
- 1 assembly per PlanePanel.
- 1 component for the detailed contour of the current
PlanePanel (with relevant option).
- 1 component for the simple contour of the current PlanePanel
- 1 component per PlanePlateGroup. The material name, material
side, thickness and offset are created as metadata. If
material data are available, a PSHELL material is
created.
- 1 surface per PlanePlate. The profile existing in
the file is used for the external loop. Holes can be
added as internal loops (with relevant option).
- 1 component per PlanePillarGroup.
- 1 set of trace lines per PlanePillar.
- 1 surface per web (with relevant option).
- 1 component per PlaneFlangeGroup.
- 1 set of trace lines per PlaneFlange.
- 1 component per PlaneStiffenerGroup.
- 1 set of trace lines per PlaneStiffener.
- 1 surface per web and per flange (with relevant
option).
- 1 component per PlaneFaceplateGroup.
- 1 set of trace lines per PlaneFaceplate.
option).
- 1 assembly per sub-PlanePanel. The contents correspond to
the ones for normal PlanePanels.
- 1 assembly per PlaneBracketGroup.
- 1 component per bracket if no sub-elements exist
(stiffeners, planeplates, flanges). 1 assembly if
sub-elements exist.
- 1 surface per PlaneBracket. The profile
existing in the file is used for the external
loop. No holes are allowed by the AVEVA Marine format. If
sub-elements are present in the current
PlaneBracketGroup, a specific component is created
for the surface in order to keep it separate from
its sub-elements.
- 1 component per PlaneStiffenerGroup sub-element (no
flanges inside the stiffener group are
allowed).
- 1 component per PlaneFaceplateGroup sub-element (no
flanges inside the faceplate group are
allowed).
- 1 component per PlaneFlangeGroup sub-element.
- 1 assembly per CurvedPanel.
CurvedPanel (with relevant option).
- 1 component per CurvedPlateGroup.
- 1 surface per CurvedPlate. The profile
loop. Internal holes are implemented.
- 1 component per CurvedStiffenerGroup.
- 1 set of trace lines per CurvedStiffener.
- 1 assembly per KnuckledPanel.
When @CreationType is “Parts”, a corresponding tree
is created but no assembly entities are created, parts are created instead. The
components are also created.
When @CreationType is “BOM Only”, a corresponding
tree is created with parts as in the previous case, but no components are actually
created.
PlanePlates, CurvedPlates and PlaneBrackets are mapped as surfaces. Other objects are
imported as curves, lying on the plates. Groups of objects may share similar
properties (such as material, material side, thickness and offset). In this case,
metadata are added to these objects, and if possible the material description is
also created. Holes of curved surfaces are not taken into consideration for this
release.
The reader instantiates objects in their nominal position, hence there may be gaps
between panels, brackets, and so forth, due to idealizations that do not take
thickness into account. Hence, no stitching between surfaces is performed on
import.
Available material fields include Young's modulus, Poisson's ratio, expansion
coefficient, and density. Yield stress and ultimate stress are not imported. Each
material is associated with a unique grade name.
When a thickness is provided, the corresponding value is given to a property.
Objects affected by material/thickness include PlanePlateGroup, PlanePillarGroup,
PlaneFlangeGroup, PlaneStiffenerGroup, PlaneFaceplateGroup, PlaneBracketGroup,
CurvedPlateGroup and CurvedStiffenerGroup.
Import Options
The
AVEVA Marine reader uses the
aveva_reader.ini file.
@BodyIdAsMetadata
| Value |
Description |
on |
Assign body identifier as
metadata. BODY_ID
off |
Do not assign body identifier as metadata (default). |
@CleanupTol
| Value |
Description |
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value
greater than the calculated auto cleanup tolerance indicates to use that specific
tolerance. Refer to the CAD Import Options. |
@ColorsAsMetadata
| Value |
Description |
integer |
Read color attributes of geometric entities as metadata with integer values.
COLOR_RGB
on |
Read color attributes of geometric entities as metadata.
COLOR_RGB
off |
Do not read color attributes (default). |
@CreationType
| Value |
Description |
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
@CurvedPlateColor
| Value |
Description |
string |
A RGB description of the color to use for curved plates, with values ranging
from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
management will be utilized. The obsolete @TribonCurvedPlateColor
is corresponding to this option and still supported. |
@CurvedSimpleContourColor
| Value |
Description |
string |
A RGB description of the color to use for curved simple contours, with values
ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedSimpleContourColor is corresponding to this option
@CurvedStiffenerColor
| Value |
Description |
string |
A RGB description of the color to use for curved stiffeners, with values
ranging from 0.0 to 1.0 (e.g. "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedStiffenerColor is corresponding to this option and
still supported. |
@DoNotMergeEdges
| Value |
Description |
on |
Preserve the original geometry edges, instead of merging them together during
the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
@ExtendSurfaces
| Value |
Description |
on |
The imported surfaces are extended to match neighbor surfaces
(default). |
off |
The imported surfaces are not extended. |
@FlangeColor
| Value |
Description |
string |
A RGB description of the color to use for flanges, with values ranging from 0.0
to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will
be utilized. The obsolete @TribonFlangeColor is corresponding to
@ImportCutoutProfiles
| Value |
Description |
on |
Import cutout profiles. |
off |
Do not import cutout profiles (default). |
@ImportDoublingProfiles
| Value |
Description |
on |
Import doubling profiles. |
off |
Do not import doubling profiles (default). |
@ImportFaceplatesAsSurfaces
| Value |
Description |
on |
Import faceplates as surfaces if the surface description is present in the
file, otherwise import as curves (default). |
off |
Import faceplates as curves. |
@ImportHoleProfiles
| Value |
Description |
on |
Import hole profiles. |
off |
Do not import hole profiles (default). |
@ImportHoles
| Value |
Description |
on |
Create holes (default). |
off |
Do not create create holes. |
@ImportMarkingProfiles
| Value |
Description |
on |
Import marking profiles. |
off |
Do not import marking profiles (default). |
@ImportNotchProfiles
| Value |
Description |
on |
Import notch profiles. |
off |
Do not import notch profiles (default). |
@ImportPanelProfiles
| Value |
Description |
on |
Create curves along the panel profiles. |
off |
Do not create curves along the panel profiles (default). |
@ImportPillarsAsSurfaces
| Value |
Description |
on |
Import pillars as surfaces if the surface description is present in the file,
off |
Import pillars as curves. |
@ImportSeamProfiles
| Value |
Description |
on |
Import seam profiles. |
off |
Do not import seam profiles (default). |
@ImportStiffenersAsSurfaces
| Value |
Description |
on |
Import stiffeners as surfaces if the surface description is present in the
off |
Import stiffeners as curves. |
@ImportSwageProfiles
| Value |
Description |
on |
Import swage profiles. |
off |
Do not import swage profiles (default). |
@ImportTapProfiles
| Value |
Description |
on |
Import tap profiles. |
off |
Do not import tap profiles (default). |
@ImportUnboundedCurvedPlates
| Value |
Description |
on |
Import curved plates lacking boundary descriptions (default). |
off |
Do not import curved plates lacking boundary descriptions. |
@ImprintStiffeners
| Value |
Description |
on |
Stiffener lines are projected onto close surfaces and create corresponding
topological modifications to these surfaces (default). |
off |
No projection is performed. |
@LegacyHierarchyAsMetadata
| Value |
Description |
on |
Generate metadata with the original CAD hierarchy within the
part. LEGACY_HIERARCHY
off |
Do not generate metadata with the original CAD hierarchy within the part
(default). |
@MetadataPrefix
| Value |
Description |
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming
for more details. |
@PlaneBracketColor
| Value |
Description |
string |
A RGB description of the color to use for plane brackets, with values ranging
management will be utilized. The obsolete @TribonPlaneBracketColor
@PlaneCutoutColor
| Value |
Description |
string |
A RGB description of the color to use for plane cutouts, with values ranging
management will be utilized. |
@PlaneDetailedContoursColor
| Value |
Description |
string |
A RGB description of the color to use for plane detailed contours, with values
@TribonPlaneDetailedContoursColor is corresponding to this option
@PlaneDoublingColor
| Value |
Description |
string |
A RGB description of the color to use for plane doublings, with values ranging
@PlaneFaceplateColor
| Value |
Description |
string |
A RGB description of the color to use for plane faceplates, with values ranging
@TribonPlaneFaceplateColor is corresponding to this option and
still supported. |
@PlaneFlangeColor
| Value |
Description |
string |
A RGB description of the color to use for plane flanges, with values ranging
management will be utilized. The obsolete @TribonPlaneFlangeColor
@PlaneHoleColor
| Value |
Description |
string |
A RGB description of the color to use for plane hole profiles, with values
@PlaneMarkingColor
| Value |
Description |
string |
A RGB description of the color to use for plane marking profiles, with values
@PlaneNotchColor
| Value |
Description |
string |
A RGB description of the color to use for plane notch profiles, with values
@PlanePillarColor
| Value |
Description |
string |
A RGB description of the color to use for plane pillars, with values ranging
management will be utilized. The obsolete @TribonPlanePillarColor
@PlanePlateColor
| Value |
Description |
string |
A RGB description of the color to use for plane plates, with values ranging
management will be utilized. The obsolete @TribonPlanePlateColor is
@PlaneSeamColor
| Value |
Description |
string |
A RGB description of the color to use for plane seam profiles, with values
@PlaneSimpleContourColor
| Value |
Description |
string |
A RGB description of the color to use for plane simple contours, with values
@TribonPlaneSimpleContourColor is corresponding to this option
@PlaneStiffenerColor
| Value |
Description |
string |
A RGB description of the color to use for plane stiffeners, with values ranging
management will be utilized. The obsolete @TribonPlaneStiffenerColor is
@PlaneSwageColor
| Value |
Description |
string |
A RGB description of the color to use for plane swage profiles, with values
@PlaneTapColor
| Value |
Description |
string |
A RGB description of the color to use for plane tap profiles, with values
@PreferDetailed
| Value |
Description |
on |
When multiple representations of a AVEVA Marine
object are available, import the most complex one (default). |
off |
object are available, import the least complex one. |
@ScaleFactor
| Value |
Description |
double |
Define the model scaling factor during import. Default is 1.0. |
@SplitComponents
| Value |
Description |
Part |
Generate part-based component (only allowed value if
CreationType=Parts). |
General |
Keep component as in CAD (only allowed value if
CreationType=TreeOfComponents). |
@StitchEdges
| Value |
Description |
on |
Edges of close surfaces are stitched together (default). |
off |
Edges of close surfaces are not stitched together. |
@SubFaceplateColor
| Value |
Description |
string |
A RGB description of the color to use for sub-faceplates, with values ranging
management will be utilized. The obsolete @TribonSubFaceplateColor
@SubStiffenerColor
| Value |
Description |
string |
A RGB description of the color to use for sub-stiffeners, with values ranging
management will be utilized. The obsolete @TribonSubStiffenerColor
@TargetUnits
| Value |
Description |
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting
legacy scripts). |
Supported Metadata
Metadata generated from the
AVEVA_OBJECT_TYPE
| Type |
Entities |
Description |
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts |
The value is a string indicating the role of the object. Currently created
values include:
- Block
- CurvedPanel
- CurvedPlateGroup
- CurvedStiffenerGroup
- DetailedPlanePanelBoundary
- KnuckledPanel
- KnuckledSubpanel
- Planebracket
- PlaneBracketGroup
- PlaneBracketFaceplateGroup
- PlaneBracketFlangeGroup
- PlaneBracketStiffenerGroup
- PlaneComplexBracket
- PlaneCutoutGroup
- PlaneDoublingGroup
- PlaneFaceplateGroup
- PlaneFlangeGroup
- PlaneHoleGroup
- PlaneMarkingGroup
- PlaneNotchGroup
- PlanePanel
- PlanePillarGroup
- PlanePlateGroup
- PlaneSeamGroup
- PlaneStiffenerGroup
- PlaneSwageGroup
- PlaneTapGroup
- Ship
- SimpleCurvedPanelBoundary
- SimplePlanePanelBoundary
BEAM_SECTION
| Type |
Entities |
Description |
entity |
parts |
Stiffener groups might contain this metadata which points the corresponding
BEAMSECTION entity. |
BEND_TYPE
| Type |
Entities |
Description |
string |
The value of the BendingRadius attribute for a plane faceplate group, a plane
flange group, a plane pillar group, or a plane stiffener group. Possible values are: |
BENDING_RADIUS
| Type |
Entities |
Description |
string |
The value of the BendingRadius attribute for a plane flange group. |
BODY_ID
| Type |
Entities |
Description |
string |
Identifier of the CAD body containing the entity. Generated when
@BodyIDAsMetadata=on |
COLOR_RGB
| Type |
Entities |
Description |
string |
Three RGB values, ranging from 0 to 255, indicating the color for the object.
Generated when the corresponding @Tribon<object>Color option is used.
COMP_ID
| Type |
Entities |
Description |
string |
surfs |
The value of the CompId attribute for a plate or bracket. |
DATA_TYPE
| Type |
Entities |
Description |
string |
The value of the DataType attribute for a panel. |
EXTENT_MAX
| Type |
Entities |
Description |
string |
The value of the maximum extent of a block or panel, as retrieved from the Max
attribute of the object. |
EXTENT_MIN
| Type |
Entities |
Description |
string |
The value of the minimum extent of a block or panel, as retrieved from the Min
FORCE_UNITS
| Type |
Entities |
Description |
string |
The value of the ForceUnits attribute for a ship units object. |
FUNCTIONAL_PROPERTY
| Type |
Entities |
Description |
string |
assems |
The value of the FunctionalProperty attribute for a panel or a group of
sub-objects of a panel. |
HEIGHT
| Type |
Entities |
Description |
string |
The value of the Height attribute for a plane flange group. |
INCLINATION
| Type |
Entities |
Description |
double array |
assems |
An array of 6 double values is added to each line belonging to pillars,
flanges, stiffeners, and faceplates. Each line is provided with two triplets of
inclination values to form 2 unit vectors. The vectors indicate the inclinations at
the endpoints of the lines in the absolute reference system. |
INSTANCE
| Type |
Entities |
Description |
string |
Two possible values: AsDefined or Reflected, to indicate if the object is on
the same side as its definition data, or if it has been reflected. |
LEGACY_HIERARCHY
| Type |
Entities |
Description |
string |
Hierarchy of an entity within a part. Generated when
@LegacyHierarchyAsMetadata=on |
LENGTH_UNITS
| Type |
Entities |
Description |
string |
assems if hierarchy as Assemblies; parts if heirarchy as Parts |
The value of the LengthUnits attribute for a ship units object. |
MATERIAL
| Type |
Entities |
Description |
entity |
parts |
Plate groups and stiffener groups might contain this metadata which points to
the corresponding MATERIAL entity. |
MATERIAL_DIRECTION
| Type |
Entities |
Description |
string |
faces |
The value of the MaterialDirection attribute for a flange, curved panel or
knuckled panel. |
MATERIAL_SIDE
| Type |
Entities |
Description |
string |
The value of the material side data for a plate group or bracket group. |
MODELUNIT
| Type |
Entities |
Description |
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts |
Model units specified in the CAD file.
- 1 = inches
- 2 = millimeters
- 4 = feet
- 5 = miles
- 6 = meters
- 7 = kilometers
- 8 = mils
- 9 = microns
- 10 = centimeters
- 11 = microinches
- 12 = decimeters
- 13 = yards
This is always generated. |
OBJECT TYPE
| Type |
Entities |
Description |
string |
parts |
A string given to parts to indicate their role in the ship organization.
Supported types include:
- Block
- CurvedPanel
- CurvedPlateGroup
- KnuckledPanel
- KnuckledSubpanel
- PlaneBracket
- PlaneBracketGroup
- PlaneFlangeGroup
- PlanePanel
- PlanePlateGroup
- PlanePillarGroup
- Ship
OFFSET
| Type |
Entities |
Description |
string |
assems if heirarchy as Assemblies; parts if hierarchy as Parts |
The value of the offset data for a plate group. |
PLATE_T
| Type |
Entities |
Description |
double |
The value of the thickness attribute for any object having a material whose
description includes a thickness. |
RENDERING_TYPE
| Type |
Entities |
Description |
string |
The value of the Type attribute for a ship rendering object. |
RootSystemID
| Type |
Entities |
Description |
string |
Generated for root system assemblies. Its value is the XML field OID. |
THICKNESS
| Type |
Entities |
Description |
string |
The value of the Thickness attribute for a plane flange group. |
TIGHTNESS
| Type |
Entities |
Description |
string |
The value of the Tightness attribute for a panel. Allowed values include:
- NonTight
- WaterTight
- Undefined
VERSION
| Type |
Entities |
Description |
string |
The value of the Version attribute for a ship. |
WEIGHT_UNITS
| Type |
Entities |
Description |
string |
The value of the WeightUnits attribute for a ship units object. |
