Edit Mesh Type and Mapping Method
Use the Freeform: Face Edit tool to edit the mesh type and mapping method of individual surfaces.
From the Mesh ribbon, click the tool.
- Optional:
On the guide bar, click
to define surface mesh options.
- Select the surface(s) to edit.
In the microdialog, select an element type and mapping
method to apply to the selected edge(s).
In the case of Map as Triangle- Tria, you can change the corner (anchor) when selecting points. After selecting the initial three points, a fourth click updates the corner. Or, the anchor point can be dragged and placed in a new location based on requirement.
- On the guide bar, click Update
Tip: Clear your selection by left-clicking in empty space.
