Review Results
Tutorial Level: Intermediate In this tutorial, you will analyze and query results.
Before you begin, copy the file(s) used in this tutorial to your
working directory.In this tutorial, you will:
- Analyze results with an .h3d file
- Query results
Analyze Results
In this step, you will analyze results with a .h3d file.
- Start HyperMesh.
- From the menu bar, click .
Browse to your working directory, select
Analysis_Setup_SOLVED.hm, and click
Open.
The model opens in the modeling window.
From the Post ribbon, select the Import Results tool
from the Result tool group.
Figure 1. - Browse and select the Analysis_Setup_SOLVED.h3d file and click Open.
From the Post ribbon, select the Contour tool.
Figure 2. - In the Contour dialog, enter Element Stresses for Name.
- For Data Type, select Element Stresses (2D & 3D).
- For Data Component, verify vonMises is selected.
- From the guide bar, click Plot.
From the Post ribbon, select the Create Contour tool
from the Contour tool group.
Figure 3. - In the Contour dialog, enter Displacements for Name.
- For Data Type, select Displacement.
- For Data Component, select Mag.
Plot.
Figure 4. -
From the Post ribbon, select the Deformed tool.
Figure 5. - In the Deformed dialog, enter Displacement for Name.
- For Data Type, verify Displacement is selected.
- Optional: Define the Uniform Scale.
- For Undeformed Shape, select Edges.
Plot.
Figure 6.
Query Results
From the Post ribbon, select the Tools tool.
Figure 7. -
In the Results Query and MinMax/Ranking/Envelope dialog,
select MinMax/Ranking/Envelope for Report Mode and click
Start.
Figure 8. - In the MinMax/Ranking/Envelope dialog, select Static Analysis and Element Stress (2D & 3D).
Set the other parameters to match Figure 9 and click Set.
Figure 9. - For Datatypes, select Displacement.
Set the other parameters to match and click Set.
Figure 10. - Optional:
Click Settings to edit the export settings of the
results.
You may have to modify the CSV separator.
For each query, click
in the Output File field.
- Choose a folder location and enter a name.
Click Apply.
The reports are generated at the specified location.
Open the exported .csv files and review the queried
results.
Figure 11.
