Change Element and Handle Display Settings
Change the visual display of elements and handles in the modeling window by configuring the element and handle display settings.
Restriction: Only available in HyperMesh
From the View Controls toolbar, click
- Beam section options - Display 1D beams as 3D elements or 1D and 3D elements.
- Shell thickness options - Display 2D shells as 3D elements or 2D and 3D elements.
- Ply layer and edges options - Display plies as independent layers, plies as independent layers with arrows connecting their direction, or ply colors at the edges of their boundaries.
- Shrink elements - Shrink all elements.
- Display points - Display all points.
- Element handles - Display element handles.
- Load handles - Display load handles.
