Select Entities
Select a single entity by
left-clicking.
Select multiple entities simultaneously using
window selection.
- For box, circle, or freehand selection, click-and-drag to draw a selection window.
- For polyline selection, click-and-drag to draw a line, then release the mouse to create an end point. Continue drawing lines, then left-click the start point, middle-mouse-click, or press Enter to close the selection window.
Tip: You can also click and drag to select multiple entities in a browser.
Window Selection Settings
Change window selection settings from the modeling window right-click context menu.
Available in HyperMesh, HyperView, and HyperGraph.
- Window Select Disabled - Disable window selection.
Allows for fast clicking without the risk of dragging a mini window.
(HyperMesh only)
- Window Shape - Change the shape of the selection window when you drag your mouse.
- Window Select Mode - Select entities that are inside,
outside, or intersecting the window shape.Note: Intersection is available for elements, lines, and surfaces.
(HyperMesh only)
- Only Select Visible - Only select visible entities.
