Publish Material Data
You can publish and unpublish material data to the database.
Select the required material from the
Figure 1. Publish Material Data
- Click OK on the confirmation dialog box. The material will be displayed on the Viewer page.
To unpublish a published material, select material from
Figure 2. Unpublish Material
- Click OK on the confirmation dialog box. The material will be removed from the Viewer page.
