Add Material
Add material data using Data Edit functionality.
  1. On the Administrator Dashboard, open Data Edit.
  2. Click and then select Add.
  3. On Add dialog box, enter the new material name.
    Figure 1. Add Material Name
  4. Select the following general material details:
    Figure 2. Add Material Details
    • Choose the required material from the Material Type list box.
    • Choose the name of the manufacturer from the Producer list box.
    • Choose the name of the provider from the Provider list box.
  5. Select the required LifeCycle State:
    • Unpublished materials stored in the databased but not visible to AMDC users.
    • Published materials are reviewed, approved, and accessible to AMDC users.
  6. On the left pane, select Single-point data and then specify values for single point material properties such as Density, Young's Modulus, and Poisson's Ratio.
    Figure 3. Single-point Data
  7. Select Plots to specify multi-point material properties for Stress-strain plots.
    Figure 4. Plots
  8. Select relevant Variant and Variant Type for the plot data.
  9. Copy the X and Y data from the source file (Excel) and select Paste Curve from the menu.
    Figure 5. Paste Curve
    • Alternatively, the properties data can be entered manually for each point data.
  10. Click Save to save the changes added to the material data.
  11. Click Commit to publish the changes to material database with version 1.
