Altair® Material Data CenterTM (AMDC) provides accurate multi-domain material properties to enable the creation of sustainable, efficient, and lightweight designs.
Discover the features of AMDC with step by step tutorials and videos.
Discover the features of AMDC with interactive tutorials.
Here’s a quick look at the latest features available with Altair One.
Explore collaborative access to simulation and data analytics technology plus scalable High Performance Computing (HPC) and cloud resources, all in one place with Altair One.
View a video to learn about the latest features of Altair One.
Sign-in to gain quick access to the Altair One applications to create appliances, manage your files or folders, browse through Altair and Altair Partner applications, community and support channels and to view your license usage.
Altair One enables users to run cloud-based simulations using the Altair License Units.
Altair One Home provides quick and easy access to your pinned applications, running desktops, recent jobs and files, and default and shared appliance statuses.
Administrator Dashboard portal providing real-time license usage for Altair managed license subscriptions.
Altair Dashboard is an administrative portal providing real-time license usage for Altair managed license subscriptions.
Altair Marketplace is a digital catalogue that you can use to find, try out, and buy Altair's and Altair Partner simulation applications and services.
Altair Material Data Center is a web-based tool accessible through all leading browsers. Launch the application to access the Altair material data. You can customize and launch the application from Favorite Apps, on the Altair One Home page.
AMDC provides license types such as Guest User, Viewer, Explorer, and ExplorerPlus. These are supported by Named User Licenses and Altair Units-based License models.
The Stick-Slip Database provides access to over 11,000 individual measurements covering a wide range of common materials available on the market.
Get instant access to an exhaustive database with thousands of simulation ready materials directly from within Altair desktop applications! This seamless integration automatically lists materials suitable for the application and lets users look up, search, compare and download CAE-ready material cards directly in the software.
Here’s a quick look at the latest features available with Altair Material Data Center.
View the main elements and the feature details in Altair Material Data Center (AMDC).
These features are explained in this tutorial.
Here are brief videos demonstrating use cases that highlight the main features of Altair Material Data Center.
Search a material or a list of materials using quick search, advanced search or scatter plots.
Select one or more materials to compare the chosen materials data.
Browse and filter materials using the predefined categories as filters in the left navigation pane that most suit your requirements.
Find similar materials in terms of mechanical, thermal, or electrical properties.
Visualize advanced and accurate material properties and curves. Also, view material impact using Global Warming Potential (GWP) and set your data preferences.
Export material data sheets with plots as a PDF and CAE simulation-ready material cards to your workstation or Altair Drive.
Share material information in an email, document or message. Recipients of the link can view the material information in AMDC.
AI assistant for AMDC.
Customize the materials data in table view. Add, remove material properties as table columns, reorder the columns, and sort them.
Set theme of AMDC.
Create and maintain different lists of favorite materials to quickly access from the catalog or maintain a list of materials for your project.
Update your material database view preferences.
An administrator is provided access to the AMDC Dashboard to access specfic administrative related tasks to maintain up to date information in the Altair Material Database.
Here are the release notes for features and updates to Altair Material Data Center.
Altair DesignAI enables you to make real-time predictions.
