*MAT_030 (SHAPE_MEMORY)
LS-DYNA Input Interface KeywordDefines a super-elastic memory shape alloy material (SMA) compatible with integrated beam, solid and shell elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_030 or *MAT_SHAPE_MEMORY | |||||||
| mat_ID | E | ||||||
| SIG_ASS | SIG_ASF | SIG_SAS | SIG_SAF | EPSL | ALPHA | YMRT | |
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Young’s
modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
| SIG_ASS | Material parameter defining the
start of phase transformation from austenite to martensite
(AS). (Real) |
| SIG_ASF | Material parameter defining the end
(AS). (Real) |
| SIG_SAS | Material parameter defining the
start of phase transformation from martensite to austenite
(SA). (Real) |
| SIG_SAF | Material parameter defining the end
(SA). (Real) |
| EPSL | Maximum residual
strain. (Real) |
| ALPHA | Material parameter measuring the
difference in response between tension and
compression. Default = 0 (Real) |
| YMRT | Martensite Young's
modulus. Default = 0.0 (Real) |
- This keyword maps to /MAT/LAW71.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
