*MAT_181 (SIMPLIFIED_RUBBER/FOAM)
LS-DYNA Input Interface KeywordDefines a rubber material with uniaxial tensile/compression test results as input curve. This material can be used with solid elements only.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_181 or *MAT_SIMPLIFIED_RUBBER/FOAM | |||||||
| mat_ID | K | Mu | |||||
| Length | Width | Thick | Table_ID | Tension | |||
Optional card 1: unloading behavior
| Fct_unl | Hys | Shape |
Optional card 2: viscous behavior (up to 12 cards)
| G_i | Beta_i |
Definition
| mat_ID | Material identifier. (Integer) |
| Poisson's ratio. (Real) |
| K | Bulk modulus. (Real) |
| Mu | Numerical Navier Stokes viscosity. Default = 0.1 (Real) |
| Length | Specimen gauge length. (Real) |
| Width | Specimen gauge width. (Real) |
| Thick | Specimen gauge thickness. (Real) |
| Table_ID | Curve or table identifier defining the force versus gauge
length and for the different strain rate value defined in the
table. (Integer) |
| Tension | Unloading rate effects option flag.
(Integer) |
| Fct_unl | Unloading curve identifier. (Integer) |
| Hys | Hysteresis unloading factor. Ignore if, unloading function is
used. 0.0 ≤ Hys ≤ 1.0 Default = 0 (Real) |
| Shape | Shape factor. Ignored if, unloading function is
used. Default = 1.0 (Real) |
| G_i | Shear relaxation modulus for ith
term. (Real) |
| Beta_i | Decay shear constant for ith
term. (Real) |
- This keyword maps to /MAT/LAW88 and /VISC/PRONY.
- Optional card 1 needs to be written if viscous parameters are defined in Optional card 2.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
