*MAT_122 (HILL_3R)
LS-DYNA Input Interface KeywordDefines an orthotropic elastoplastic material using linear or tabulated stress versus plastic strain input.
This material is only compatible with shell elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_122 or *MAT_HILL_3R
mat_ID ρ i E ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A65@ HARD H1 H2
R00 R45 R90 LCSS
AOPT
A1 A2 A3
V1 V2 V3 BETA
Definition
mat_ID Material Identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young’s modulus.
(Real)
[ Pa ]
ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A65@ Poisson’s ratio.
Default = 0 (Real)
HARD Hardening flag:
= 1
Linear hardening
= 3
Tabulated hardening, stress versus plastic strain curve is specified
(Integer)
[ Pa ]
H1 If HARD=1: Tangent hardening modulus.
(Real)
[ Pa ]
H2 If HARD=1: Yield stress
(Real)
[ Pa ]
R00, R45, R90 Lankford coefficients.
(Real)
LCSS Stress versus plastic strain curve identifier.
(Integer)
AOPT Material axis flag.
= 0 (Default)
Locally orthotropic axes defined by node
= 2
Globally orthotropic axes defined by vector
= 3
Locally orthotropic axes defined with element normal
< 0
The absolute value A O P T MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaabdaqaai aadgeacaWGpbGaamiuaiaadsfaaiaawEa7caGLiWoaaaa@3DD3@ is a coordinate system identifier which defines the orthotropic directions.
(Real)
A1, A2, A3 Vector defining first orthotropy direction for AOPT=2.
(Real)
V1, V2, V3 A vector which in combination with element normal defines the first orthotropy direction for AOPT=3.
(Real)
BETA Material angle for AOPT = 0 or 3.
(Real)
[ deg ]
  1. This keyword maps to /MAT/LAW43 (HILL_TAB) and orthotropic shell property card.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
