*MAT_119 (GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with 6 degrees of freedom (DOFs). Different loading and unloading behavior can be specified.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_119 or *MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM
mat_ID ρ i KT KR H
T_r T_s T_t R_r R_s R_t
TU_r TU_s TU_t RU_r RU_s RU_t
TD_r TD_s TD_t RD_r RD_s RD_t
Blank Line
ufT_r ufT_s ufT_rt wfT_r wfT_s wfT_t
ufC_r ufC_s ufC_rt wfC_r wfC_s wfC_t
Blank Line
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
KT Stiffness for translational DOFs.
(Real)
[ N m ]
KR Stiffness for rotational DOFs.
(Real)
[ Nm rad ]
H Unloading spring hardening flag.
= 0 (Default)
Elastic spring.
= 1
Nonlinear unloading and isotropic hardening.
= 2
Elastic hysteresis in unloading.
(Integer)
T_r, T_s, T_t Curve identifier for force versus displacement loading curve in the r, s, and t directions.
(Integer)
R_r, R_s, R_t Curve identifier for moment versus rotation loading curve in the r, s, and t directions.
(Integer)
TU_r,TU_s¸ TU_T Curve identifier for force versus displacement unloading curve in the r, s, and t directions.
(Integer)
RU_r, RU_s, RU_t Curve identifier for moment versus rotation unloading in the r, s, and t directions.
(Integer)
TD_r, TD_s, TD_t Curve identifier for force versus velocity damping curve in the r, s, and t directions.
(Integer)
RD_r, RD_s, RD_t Curve identifier for moment versus rotational velocity damping curve in the r, s, and t directions.
(Integer)
ufT_r,ufT_s, ufT_t Failure displacement in tension input as a positive value in the r, s, and t directions.
(Real)
[ m ]
wfT_r, wfT_s, wfT_t Failure rotation in tension input as a positive value in the r, s, and t directions.
(Real)
[ rad ]
ufC_r, ufC_s, ufC_t Failure displacement in compression input as a positive value in the r, s, and t directions.
(Real)
[ m ]
wfC_r, wfC_s, wfC_t Failure rotation in compression input as a positive value in the r, s, and t directions.
(Real)
[ rad ]
  1. This keyword maps to six degrees of freedom (DOF) spring material, /MAT/LAW113 (SPR_BEAM) if SCOOR=-2 or 2 in *SECTION_BEAM or /MAT/LAW108 (SPR_GENE).
  2. DOF directions are defined by the coordinate system defined in *SECTION_BEAM. By default, the global coordinate system is used.
  3. This material is only used with discrete beams ELFORM = 6 and CA > 0 in *SECTION_BEAM.
  4. Beam elements with zero initial length are recommended.
  5. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
