*MAT_054 (ENHANCED_COMPOSITE_DAMAGE)
LS-DYNA Input Interface KeywordDefines an orthotropic shell composite material for unidirectional layers with Chang-Chang failure model.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_054 or *MAT_ENHANCED_COMPOSITE_DAMAGE
mat_ID ρ i E1 E2 E3 ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A61@ 12
G12 G23 G31 AOPT
XP YP ZP A1 A2 A3 MANGLE
V1 V2 V3 D1 D2 D3
TFAIL
XC XT YC YT SC BETA
Blank card
Blank card
Blank card
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E1 Young’s modulus in material directions 1.
(Real)
[ Pa ]
E2 Young’s modulus in material directions 2.
(Real)
[ Pa ]
E3 Young’s modulus in material directions 3.
(Real)
[ Pa ]
ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A61@ 12 Poisson’s ratio between directions 1 and 2.
(Real)
[ Pa ]
G12 Shear modulus in direction 12.
(Real)
[ Pa ]
G23 Shear modulus in direction 23.
(Real)
[ Pa ]
G31 Shear modulus in direction 31.
(Real)
[ Pa ]
AOPT Material axis flag.
= 0 (Default)
Orthotropic axes defined by element nodes.
= 1
Orthotropic axes defined by the vector between reference point and the solid center.
= 3
Orthotropic axes defined by Vector V and element normal vector.
= 4
Orthotropic axes defined with reference point and normal to vector V.
AOPT < 0
The absolute value AOPT is a coordinate system identifier which defines the orthotropic directions.
(Integer)
XP, YP, ZP Coordinates of reference point for AOPT = 1 and 4.
(Real)
A1, A2, A3 Vector defining first orthotropy direction for AOPT = 2.
(Real)
MANGLE Material angle for AOPT = 1 and 3.
(Real)
V1, V2, V3 A vector which in combination with element normal defines the first orthotropy direction for AOPT = 3 and 4.
(Real)
D1, D2, D3 Components of vector for AOPT = 2.
(Real)
TFAIL Time step for element deletion.
(Real)
[ s ]
MANGLE Material angle for AOPT = 0 and 3.
(Real)
[ deg ]
XT Yield stress in tension in direction 1.
(Real)
[ Pa ]
XC Yield stress in compression in direction 1.
(Real)
[ Pa ]
YT Yield stress in tension in direction 2.
(Real)
[ Pa ]
YC Yield stress in compression in direction 2.
(Real)
[ Pa ]
SC Maximum shear stress.
(Real)
[ Pa ]
BETA Shear scaling factor.
Default = 0 (Real)
  1. This material law is mapped to /MAT/LAW25 (COMPSH) (Iform=0) and /FAIL/CHANG.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
