Add Queries to a Simulation
You can define queries with a unique Start Time, End Time, and Interval Time similar to those in EDEM Analyst.
Select the Simulator Queries checkbox.
The Setup Simulator Queries dialog box is displayed.
In the Setup Simulator Queries dialog box, define the
queries.
After you have defined the queries, start the simulation.
The
csvfiles will be copied to the folder which contains the.demfile associated with the simulation.Note: For more information about the data types which can be exported using Queries, see Results Data.
