You can generate images of the simulation automatically during run-time. This is most
useful during simulation monitoring on remote machines or machines that do not have
graphical output.
To configure image export settings:
Select the Simulator tab and then select the Image
Generation checkbox to enable image generation.
Click Setup Image Generation… to specify the image setup
options.
In the Setup Image Generation dialog box, click
Add Image Config to create a new configuration for
export and specify the following details:
For
Specify
Name
Specify the identifier for the configuration.
Filepath
Indicates the output path for the images. This path is
relative to the simulation’s .dem file.
Each configuration will generate many images, numbered
sequentially with a suffix. The latest images will also be
saved without a suffix, for convenience.
View Name
Indicates the camera location and direction. You can
configure available views in the EDEMtoolbar.
Start Time, End Time
Indicates the simulation time range during which this
configuration will generate images.
Interval Time
Indicates the frequency of the images that will be
generated within the selected time range.
Display Mode
Select the display for geometry meshes.
Geometry Opacity
Select the transparency of geometries (0 being fully
transparent, and 1 fully opaque).
Display Particles
Select the checkbox to display particles. If you do not
select the checkbox, only geometries are displayed.
Color Frozen Particles
Select to color frozen particles in a light-blue color,
especially for simulations using Dynamic Domain.
Image Width, Image Height
Indicates the dimensions of the exported images.
Run the simulation.
The images will be exported automatically according to the configured
settings.
