2021.1 API Programmer's Guide
Classic Loads to Engineering Loads
Specific keywords (see table below) previously mapped to classic loads have been migrated to engineering loads for the LS-DYNA solver interface. See loads data names documentation for more details.
Mapping these keywords to the engineering loads brings several benefits: more representative visualization, ID pool support, more efficient load management, and easier switch between load types. Classic load support is still available for the affected keywords as a convenience, but it is not recommended to use them. Scripts that rely on the creation of classic loads will still work. For more information on how to create engineering loads or convert classic loads to engineering loads, refer to the Engineering Loads section of the 2020 API Programmer’s Guide.
| LS-DYNA Keywords | Engineering Loads Entity |
| *LOAD_GRAVITY_PART | Acceleration |
| *LOAD_GRAVITY_PART_SET | |
| *BOUNDARY_PRESCRIBED_MOTION_NODE | |
| *BOUNDARY_PRESCRIBED_MOTION_SET | |
| *BOUNDARY_PRESCRIBED_MOTION_RIGID | |
| *BOUNDARY_SPC_NODE | Constraints |
| *BOUNDARY_SPC_SET | |
| *BOUNDARY_CONVECTION_SET | Fluxes |
| *BOUNDARY_RADIATION_SET | |
| *LOAD_NODE_POINT | Forces |
| *LOAD_NODE_SET | |
| *LOAD_RIGID_BODY | |
| *LOAD_NODE_POINT | Moments |
| *LOAD_NODE_SET | |
| *LOAD_SHELL_ELEMENT | Pressures |
| *LOAD_SHELL_SET | |
| *LOAD_SEGMENT | |
| *LOAD_SEGMENT_SET | |
| *LOAD_BEAM_ELEMENT | |
| *LOAD_BEAM_SET | |
| *INITIAL_TEMPERATURE_NODE | Temperatures |
| *INITIAL_TEMPERATURE_SET | |
| *BOUNDARY_TEMPERATURE_NODE | |
| *BOUNDARY_TEMPERATURE_SET | |
| *LOAD_THERMAL_CONSTANT_NODE | |
| *LOAD_THERMAL_CONSTANT | |
| *LOAD_THERMAL_VARIABLE_NODE | |
| *LOAD_THERMAL_VARIABLE | |
| *INITIAL_VELOCITY_NODE | Velocities |
| *INITIAL_VELOCITY | |
| *INITIAL_VELOCITY_RIGID_BODY | |
| *INITIAL_VELOCITY_GENERATION | |
Loadcollectors to Analysisparameters
Specific keywords previously mapped to the loadcols entity have been migrated to the new analysisparameters entity for the following profiles: Nastran and OptiStruct.
Refer to analysisparameters data names documentation for more details. Scripts that created or queried the load collector entity for the keywords listed in the table below must be updated to use the new analysis parameters entity.
- Before – Created as a load
collector
*createentity loadcols name="loadcol1" cardimage="EIGRL" - After – Created as an analysis
parameter
*createentity analysisparameters name="analysisparam1" real_eigen_type="EIGRL" - Set the V2 value on the EIGRL card to
500.0
*setvalue analysisparameters id=$id STATUS=1 v2=500
| Keyword | Analysisparameters Entity |
| EIGRL | Config: 301 Type: EIGRL |
| EIGRA | Config: 301 Type: EIGRA |
| EIGRD | Config: 301 Type: EIGRD |
| EIGC | Config: 302 Type: EIGC |
| NLPARM | Config: 303 Type: NLPARM |
| NLADAPT | Config: 304 Type: NLADAPT |
| NLMON | Config: 305 Type: NLMON |
| NLOUT | Config: 306 Type: NLOUT |
| NLPRINT | Config: 307 Type: NLPRINT |
| NLENRG | Config: 308 Type: NLENRG |
| BASELIN | Config: 309 Type: BASELIN |
| NLOUT | Config: 305 Type: NLOUT |
Reference Geometries
Keywords defining reference geometries in LS-DYNA, Radioss and PAM-CRASH solver interfaces are mapped to the new referencegeometries entity. Creating and modifying the new entity is done using the *createentity and *setvalue commands.
The commands *createreferencegeometry, *reviewreferencegeometry, *updatereferencegeometry should not be used for creating, reviewing, or updating reference geometry. Any scripts that rely on using control volumes, controlcards, or table entities to create reference geometry-related keywords in crash profiles should be updated to the referencegeometries entity.
- *INITIAL_FOAM_REFERENCE_GEOMETRY
- *INITIAL_FOAM_REFERENCE_GEOMETRY_RAMP
- *AIRBAG_REFERENCE_GEOMETRY
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH
- *AIRBAG_REFERENCE_GEOMETRY_RDT
- *AIRBAG_REFERENCE_GEOMETRY_ID
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH_ID
- *AIRBAG_REFERENCE_GEOMETRY_RDT_ID
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT_ID
- *INITIAL_AIRBAG_PARTICLE_POSITION
- *AIRBAG_SHELL_REFERENCE_GEOMETRY
- *AIRBAG_SHELL_REFERENCE_GEOMETRY_RDT
- *AIRBAG_SHELL_REFERENCE_GEOMETRY_ID
- *AIRBAG_SHELL_REFERENCE_GEOMETRY_RDT_ID
*createentity referencegeometries config=101*createentity referencegeometries config=102*createentity referencegeometries config=103*createentity referencegeometries config=104The following Radioss keyword is mapped from the controlvolumes entity to the referencegeometries entity: /XREF.
- /EREF/SH3N
- /EREF/SHELL
- /EREF/TETRA4
- /EREF/BRICK
The following Radioss keyword is mapped from the controlcards entity to the referencegeometries entity: /REFSTA.
*createentity referencegeometries config=201*createentity referencegeometries config=202*createentity referencegeometries config=203*createentity referencegeometries config=204*createentity referencegeometries config=205*createentity referencegeometries config=206- METRIC/ NODES/
- METRIC/ BAR/
- METRIC/ MEMBR/
- METRIC/ TETRA4/
- METRIC/ SOLID/
- METRIC/ PENTA6/
- METRIC/ TETRA10/
*createentity referencegeometries config=401*createentity referencegeometries config=402*createentity referencegeometries config=403*createentity referencegeometries config=404*createentity referencegeometries config=405*createentity referencegeometries config=406*createentity referencegeometries config=407*setvalue referencegeometries id=$id nodes_table_node={1 2 3 4}
*setvalue referencegeometries id=$id nodes_table_x={0.1 0.2 0.3 0.4}*setvalue referencegeometries id=$id elems_table_elem={1 2 3 4}
*setvalue referencegeometries id=$id elems_table_n1={10 11 12 13}*setvalue referencegeometries id=$id birthtoggle=1
*setvalue referencegeometries id=$id birth=10.5New Commands
- Connector/Attachments
- hm_ce_getfilteredconfignames
- *DeleteUC
- *UpdateController
- Data Names
- airbagfoldingsequences
- airbagfolds
- airbags
- analysisparameters
- behaviors
- referencegeometries
- Feature Recognition
- General/Core
- Geometry
- HMASCII
- *airbagfoldingsequences
- *airbagfolds
- *airbags
- *analysisparameters()
- *behaviors()
- *referencegeometries()
- Meshing
- Template Commands
- *airbagfolds
- *airbags
- *behaviors()
- Template Functions
Modified Commands
- Data Names
- responses - Updated the list of responserequesttype values.
- General/Core
- hm_getvalue - Resolved an issue with incorrect value being returned for certain colors when querying color entity data name.
- Meshing
- hm_getbatchparams - Updated the surface_holes_table options.
- *batchparams_update - Updated the surface_holes_table options.
- *compute_midmesh_thickness - Added new options RegroupThicknessVariationFactor, RenameRetainedComponents, and ThicknessAssignMethod to enhance thickness grouping. Removed the ThicknessOutputOption value PropertyOnComponents.
- Data Names
- attachments – Added new data name aegroup.
- attachmentcontrols - Added new data names createelements, duplicateelems, feature, and maxlayers.
- connectorgroups – Added new data name attachments.
- designvars
- topology - Added new data names holeinst, holerad, levelset, nholesx, nholesy and nholesz.
- explorations - Added new explorationtype value 3.
- failures – Added new data name epsp_min, new PAM-CRASH support.
- features - Added new options associativity,config_color, dim_sides_selection, elem_ids, feature_height, feature_length, feature_minwidth, feature_maxwidth, feature_type, feature_shape, fillet_maxangle, fillet_maxradius, fillet_minangle, fillet_minradius, fillet_ratio, hole_axis, hole_center, hole_ratio, hole_size1, hole_size2, ids, invalid, line_ids, logo_concavityfactor, logo_size, logo_string, node_ids, region_2delems, region_2dedges, region_3delems, region_lines, region_surfs, solidhole_axis, solidhole_blind, solidhole_bottomradmax, solidhole_bottomradmin, solidhole_bottomrims, solidhole_center, solidhole_topradmax, solidhole_topradmin, solidhole_toprims, and surf_ids.
- loads
- accelerations – Added new data names for LS-DYNA engineering loads: activation_time, add_part_construct_stage, crash_dir_flag, crash_dofstring and load_body_opt, curveid, deactivation_time, displayname, dyn_relax_evolve_fn, entity_select_option, keyword_name, load_dof, magnitude, motion_rigid_local_option, motion_type, motion_vec_dir, nodal_rigid_body, plane_axis_coord1, plane_axis_coord2, rem_part_construct_stage, rigid_part, rigidbody_option, and vector.
- constraints – Added new data names for LS-DYNA engineering loads: activation_time, ang_vel_center, curveid, deactivation_time, displayname, dof1, dof2, dof3, dof4, dof5, dof6, inputsystem, keyword_name, load_boundary_nodes, load_dof, magnitude, motion_rigid_local_option, motion_type, motion_vec_dir, nodal_rigid_body, plane_axis_coord1, plane_axis_coord2, plane_node2, plane_node3, rel_disp_ref_body, rigid_part, rigidbody_option, sort_nodes, symmetry_repetition_dir, and time_activate_option.
- fluxes – Added new data names for LS-DYNA engineering loads: curveid, env_temp_const, env_temp_evolve_fn, magnitude, radiation_type, and thk_shell_surf_temp.
- forces – Added new data names for LS-DYNA engineering loads: crash_dir_flag, curveid, follower_load, force_ev_fn, inputsystem, load_dof, magnitude, plane_node1, plane_node2, plane_node3, rigid_part and vector.
- moments – Added new data names for LS-DYNA engineering loads: crash_dir_flag, curveid, follower_load, force_ev_fn, inputsystem, load_dof, magnitude, plane_node1, plane_node2, plane_node3, rigid_part and vector.
- pressures – Added new data names for LS-DYNA engineering loads: activation_time, beam_axial_dir, box_region_def, curveid, displayname, element_inclusion_option, keyword_name, magnitude, masking_fn_projection_vec, motion_vec_dir, pressure_lower_limit, pressure_mask_fn, rgd_bdy_vel_opt_overwrite, shell_part, and timestep_offset.
- temperatures – Added new data names for LS-DYNA engineering loads: box_region_def, curveid, dyn_relax_evolve_fn, exempt_node_dyn_rel_temp_sf_evolve_fn, exempt_node_scaled_temp, exempt_node_temp, exempt_node_temp_sf_evolve_fn, exempt_nodes, magnitude, scaled_temp, and thk_shell_surf_temp.
- modelcheckchecks – Added new data names report and concernedids.
- modules - Added new data name rep_comment.
- positions – Added new config value 408 and new data name positions.
- rbe3 – Added new inputs independentnodesets, independentnodesetcoeffs, independentnodesetidofs, nset, rx, ry, rz, tx, ty, tz, and wt.
- responses - Added new response value 12.
- sets – Added new style value 3.
- topology - Added new data names levelset, holeinst, holerad, nholesx, nholesy, and nholesz.
- weldlines - Added new data name active_weld_type.
- General/Core
- hm_holedetectionsettubeparams – Added new input ?merge_connected_barrels=<>?.
- hm_wadlinessetoptions - Added new options active_hood_method and side_reference_resolution.
- *detectandcreateface2facecontacts - Added Nastran (NX) support.
- *setoption/hm_getoption – Added new options geometry_style_view_cube, reflector_show_view_cube, rotator_show_view_cube, topoedgecolorauto and topofacecolorauto. Added new topoedgecolor value 4 and topofacecolor value 28.
- *swapcards - Added Nastran (NX) support.
- Library
- *hwct_savetolibrary - Added new option repcomment=<value>.
- Meshing
- *rbody_mesh - Added new shared_edge_flag values 6, 10, 11, 12, 13, 14, 15, and 16.
- *update1delements - Added new options connectiontol, contacttol, cutlocation, planebase, planeheight, planenormal, planewidth, refentid, refentname, refentsearchtol, refenttype, taperangle, targetenttype, and targetmark.
- Subsystems
- *modent_saverepresentation - Added new option repcomment=<value>.
Removed Commands
- Data Names
- attachmentcontrols - Removed data name findhole.
- loads
- constraints - Removed data name for Radioss: constraint_flag.
- General/Core
- *setoption/hm_getoption - Removed topoedgecolor and topofacecolor value 1.
