hm_findthinsolidproximity
Finds and returns the proximate solid pairs for a given set of selected solids.
hm_findthinsolidproximity entity_type mark_id
HyperMesh Tcl Query Command
Finds and returns the proximate solid pairs among selected solids. A list of proximate solid pair data is returned containing the list of two solid IDs that are in proximity, the type of joint (BUT, LAP, or TEE), the list of faces in proximity from the first solid, and the list of faces in proximity from the second solid.
- entity_type
- The type of entity to find proximity for. Only solids are supported.
- mark_id
- The ID of the mark containing the set of solids selected to find proximity. Valid values are 1 and 2.
Examples
To find all the thin solids that are in proximity in the model:
*createmark solids 1 all
hm_findthinsolidproximity solids 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.1
