hm_getbatchparams
Query the values of global mesh parameters.
hm_getbatchparams param1 ?param2? ?param3? ... ?paramN?
HyperMesh Tcl Query Command
- param
- The name of the parameter to query. Valid values can be found in *batchparams_update.
Examples
To query the 2nd row of the first coordsfile
table:
hm_getbatchparams surface_holes_table = {table_id=0 row_id=1}To query the entire default 2d rectangle holes
table:
hm_getbatchparams surface_holes_table = {table_id=default shape=rectangle}To query the 1st row of 3d holes
table:
hhm_getbatchparams solid_holes_table = {row_id=0}To query the entire 3d holes
table:
hm_getbatchparams solid_holes_tableTo query the 2nd row of fillet
table:
hm_getbatchparams surface_fillets_table = {row_id=1}To query the entire fillet
table:
hm_getbatchparams surface_fillets_tableTo get the element size:
hm_getbatchparams element_sizeErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
2021.1 - Updated the surface_holes_table options and the list of examples.
