*wadlines_windscreenperiphery
Creates the hard part zone for the pedestrian tool by duplicating and trimming vehicle outer components with the test zone boundaries.
*wadlines_windscreenperiphery windscreen_comps_mark=<mark_id> ?line_list?={<value>} ?offset=<value>? ?step_size=<value>?Type
HyperMesh Tcl Modify Command
- windscreen_comps_mark=<mark_id>
- The ID of the mark containing the input windscreen components. Valid values are 1 and 2.
- line_list={<value>}
- The list of IDs of four frit lines defining the boundary of the windscreen. This is an optional argument, and if not provided, the edges of the windscreen component are used. The number of line IDs provided should be 4.
- offset=<value>
Total offset inwards from the windscreen edges or frit lines for the windscreen periphery zone. Default = 165.0.
- step_size=<value>
- The windscreen zone is created by incrementally offsetting the windscreen edge inwards by step size until the total offset provided is reached. Default = 10.0.
To create a hard part zone using lines 1-4, offset of 165.0 and step size of
5.0:
*createmark comps 1 displayed
windscreen_comps_mark=1
line_list={1 2 3 4}
offset=165 step_size=5Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.1
