*analysisparameters()
Creates an analysis parameter in HMASCII format.
*analysisparameters (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the friction.
- name
- The name of the friction.
- color
- The color of the friction. Valid values are 1-64.
To create an analysis parameter with ID 100, name "my-entity", and color
1:
*analysisparameters(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2021.1
