*swapcards
Swaps the card image of an entity.
*swapcards entity_type mark_id ?target_card_image?
HyperMesh Tcl Modify Command
Swaps the card image of an entity. This command is used to swap the
card image of selected contact entities specific to the supported
solver profile and retain main and secondary entities.
Note:
- In OptiStruct, it is used to swap groups CONTACT and TIE.
- In Nastran (NX) it is used to swap groups BCTSET and BGSET.
- entity_type
- The type of entity to update. Must be set to groups.
- mark_id
- The ID of the mark containing the groups to update. Valid values are 1 and 2.
- target_cardimage
- The target card image to which the entity need to be swapped. If not specified, a default mapping is done.
To swap contacts with IDs 1 and 2:
*createmark groups 1 1 2
*swapcards groups 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
2021.1 - Added Nastran (NX) support.
