*createsinglewallbulkhead
Creates a single wall bulkhead inside a C section formed by selected elements.
*createsinglewallbulkhead elems_mark=<mark_id> dom_elem_mark=<mark_id> normal={<value>} plane_point={<value>} flange_width=<value> mesh_elem_size=<value> thickness=<value> offset=<value> materialid=<value> realizeconnectors=<value>? ?connectorcontrolid=<value>?Type
HyperMesh Tcl Modify Command
This command creates single wall bulkhead at the C section formed by selected elements with given width of flanges and sets the thickness property card with given thickness.
- elems_mark=<mark_id>
- The ID of the mark containing the elements of the C section. Valid values are 1 and 2.
- dom_elem_mark=<mark_id>
- The ID of the mark containing the elements from the dominant face of C section. Valid values are 1 and 2.
- normal={<value>}
- The normal direction defining the main bulkhead plane.
- plane_point={<value>}
- The coordinates of the base point defining the position of the bulkhead.
- flange_width=<value>
The width of the bulkhead flanges.
- mesh_elem_size=<value>
- The element size used for the bulkhead mesh.
- thickness=<value>
- The thickness value assigned to the property card of the bulkhead.
- offset=<value>
- The extra offset value for the bulkhead flanges. The default offset value is calculated from the C section thickness and the specified bulkhead thickness.
- materialid=<value>
- The ID of the material which will be set as the material property for the created bulkhead. This is an optional argument.
- realizeconnectors=<value>
- The flag enabling connector realizations.
- connectorcontrolid=<value>
- The ID of the connectorcontrol entity used to realize the connectors.
To create a single wall bulkhead in a C section defined by elements 1-9889, with elements
8396, 8418 from the dominant face, with the base point at x= 42.6, y = -21.9, z = 223.9, the
normal vector (0, 0, -1), the width of flanges 32.0, element size of 3.0, thickness of 2.0
and with no extra
offset:
*createmark elements 1 1-9889
*createmark elements 2 8396 8418
*createsinglewallbulkhead elems_mark=1 dom_elem_mark=2 normal={0 0 -1} plane_point={42.6 -21.9 223.9} flange_width=32.0 mesh_elem_size=3.0 thickness=2.0 offset=0.0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.1
2021.2 - Added new option materialid.
2022 - Added new options connectorcontrolid and realizeconnectors.
