hm_getmultilevelreferenceentities
Finds all the multi-level reference entities for the entities specified on the input mark.
hm_getmultilevelreferenceentities entity_type inputmark=<mark_id> outputmark=<mark_id>
HyperMesh Tcl Query Command
Finds all the multi-level reference entities for the entities specified on the input mark. Each type of entity that is referenced by the specified input entities is returned in a list, and the found entities are placed on the corresponding mark with the specified output mark ID.
- entity_type
- The type of entity for which related entities are to be found.
- inputmark=<mark_id>
- The ID of the mark containing the input entities. Valid values are 1 or 2.
- outputmark=<mark_id>
- The ID of the mark in which to place the found referenced entities. Valid values are 1 and 2.
Examples
To obtain all the entities related to components ID 1 and 2 on mark 1:
*createmark comps 1 1 2
hm_getmultilevelreferenceentities comps inputmark=1 outputmark=2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
2021.1
