poIImagePlane GetColorAlphaTarget
Gets the color that will be made transparent when the ColorAlpha image post-processing filter is active on the image plane.
Imageplane_handle GetColorAlphaTarget
HyperView Tcl Query
The image plane offers several image post-processing filters that can be applied on the image or video. The ColorAlpha filter makes the target color in the image or video transparent. This command returns the RGB value of the target color as a series of three values between 0 and 255.
Console Output:
Filter Type: ColorAlpha
Filter Mode: Equal
Alpha Color Target: 255 255 255
Alpha Color Tolerance: 18
MipMap Mode: Linear1
No errors.
Warnings:
To create one image plane, configure the ColorAlpha filter, and then
query the object for its
settings:
hwi OpenStack
if {[catch {
hwi GetActiveClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
imageplane_handle SetFileName g:/samples2/VideoOverlay/Altair_logo.jpg
imageplane_handle SetMode background
imageplane_handle SetCrop 0 0 0.9995 0.995
imageplane_handle SetFilterType ColorAlpha;
imageplane_handle SetFilterMode equal;
imageplane_handle SetColorAlphaTarget "255 255 255"
imageplane_handle SetColorAlphaTolerance 18
imageplane_handle SetMipMapMode Linear1
puts " Filter Type: [imageplane_handle GetFilterType]";
puts " Filter Mode: [imageplane_handle GetFilterMode]";
puts " Alpha Color Target: [imageplane_handle GetColorAlphaTarget]";
puts " Alpha Color Tolerance: [imageplane_handle GetColorAlphaTolerance]";
puts " MipMap Mode: [imageplane_handle GetMipMapMode]";
client_handle Draw
} result]} {
global errorInfo;
puts stderr $result;
puts "[session_handle GetError]";
puts stderr "*** Tcl TRACE ***";
puts stderr $errorInfo;
} else {
puts "No errors.";
puts "Warnings: ";
puts " [session_handle GetError]";
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid.
