poIImagePlane SetStretchToFit
Sets an image plane in the background or foreground mode to a predefined window location.
Imageplane_handle SetStretchToFit val
HyperView Tcl Modify
When an image plane is in background or foreground mode, setting the StretchToFit flag to true will cause the image or video to be stretched to consume the entire HyperMesh window when drawn. This command modifies this flag.
- val
- True or False to indicate whether to stretch the image (or not).
To create two image planes, then set the stretch-to-fit flag (and other basic properties)
on one of
them:
hwi OpenStack
if {[catch {
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
imageplane_handle SetFileName g:/samples2/VideoOverlay/logo1.jpg
imageplane_handle SetMode background
imageplane_handle ReleaseHandle
set ipid2 [ipc_handle AddImagePlane Video1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid2
imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
imageplane_handle SetLabel "Company Logo";
imageplane_handle SetAlpha 80
imageplane_handle SetMode foreground
imageplane_handle SetAssociatedModelID 1
imageplane_handle SetCullAngle 45
imageplane_handle SetBackFaceVisibility true
imageplane_handle SetCrop 0.2 0.2 0.8 0.8
imageplane_handle SetStretchToFit false
imageplane_handle SetMaintainAspectRatio false
client_handle Draw
} result]} {
global errorInfo;
puts stderr $result;
puts "[session_handle GetError]";
puts stderr "*** Tcl TRACE ***";
puts stderr $errorInfo;
} else {
puts "No errors.";
puts "Warnings: ";
puts " [session_handle GetError]";
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid.
