poIImagePlane GetSyncMode
Gets the mode used to synchronize an image plane video with a model animation.
Imageplane_handle GetSyncMode
HyperView Tcl Query
This command returns the sync mode currently applied to the image plane:
- Manual (default)
- No current synchronization or user has modified the synchronization.
- Length
- The video and model start and stop animating at the same time.
- Framerate
- The video and model animate at the same number of frames per second.
To get the sync mode of an image plane with an index of
1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle GetSyncMode
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid.
