poIImagePlane LocateByMultPoints
Transforms the model based on a list of points to align it to a 2D image plane.
Imageplane_handle LocateByMultPoints pointList execute
HyperView Tcl Modify
This command aligns the model with an image plane. The model is transformed to match the perspective of an image.
- pointList
- String containing at least seven corresponding model and image points that would be used for an alignment
- execute
- Boolean value set to true will calculate alignment and update the view. A false value will calculate alignment but not store or update the view, it is used to update alignment error in order to give users a sense of how good the current alignment points are.
To set the sync model of an image plane with index 1 to a model with the index of
1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
set pt_list [image_plane_handle LocateByMultPoints " 9 1 420608 @ 1 233 1 608 1 420840 @ 1 233 1 840 1 420314 @ 1 233 1 314 1 409148 @ 1 163 1 1148 1 438182 @ 1 162 1 182 1 391833 @ 1 188 1 4833 1 429052 @ 1 138 1 52 1 349822 @ 1 191 1 2822 1 409119 @ 1 163 1 1119 186 164 55 215 315 255 476 266 558 380 637 344 339 380 578 297 475 170 " true]
hwi CloseStackErrors
Returns HW_InvalidHandle is image plane handle is invalid. Returns HW_Error if active model or video stream is not valid. Returns -2 if invalid node IDs are found in pointList.
