poIImagePlane SetFilterMode
Sets the image post-processing filter mode for the image plane.
Imageplane_handle SetFilterMode mode
HyperView Tcl Modify
The image plane offers several image post-processing filters that can be applied on the image or video. This command sets/changes the filter mode being used for the image plane.
- mode
- The filter mode name. Valid values are returned by GetFilterModeList. They are different for each filter type.
Context
To create one image plane, and use the edge detection filter to draw the edges in black,
and then use the color alpha filter to remove all “white” from the image (making those areas
of the image transparent):
Note: The image plane without the filter is shown in Figure 1
(below). The image plane with the edge detection filter active is shown in Figure 2
(below).
hwi OpenStack
if {[catch {
hwi GetActiveClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
imageplane_handle SetFileName g:/samples2/VideoOverlay/Altair_logo.jpg
imageplane_handle SetMode background
imageplane_handle SetCrop 0 0 0.9995 0.995
imageplane_handle SetFilterType ColorAlpha;
imageplane_handle SetFilterMode equal;
imageplane_handle SetColorAlphaTarget "255 255 255"
imageplane_handle SetColorAlphaTolerance 18
imageplane_handle SetMipMapMode Linear1
puts " Filter Type: [imageplane_handle GetFilterType]";
puts " Filter Mode: [imageplane_handle GetFilterMode]";
puts " Alpha Color Target: [imageplane_handle GetColorAlphaTarget]";
puts " Alpha Color Tolerance: [imageplane_handle GetColorAlphaTolerance]";
puts " MipMap Mode: [imageplane_handle GetMipMapMode]";
client_handle Draw
} result]} {
global errorInfo;
puts stderr $result;
puts "[session_handle GetError]";
puts stderr "*** Tcl TRACE ***";
puts stderr $errorInfo;
} else {
puts "No errors.";
puts "Warnings: ";
puts " [session_handle GetError]";
hwi CloseStackThe image plane without the filter is shown in Figure 3. The image plane with the filter
active is shown in Figure 4.
Error
Returns HW_InvalidHandle if the image plane handle is invalid, or poIInvalidImgFilterMode if an unexpected error occurred while processing the specified media file.
