poIImagePlane SetTrackingMode
Sets the current tracking mode for the image plane.
Imageplane_handle SetTrackingMode mode
HyperView Tcl Modify
This command sets the current tracking mode for the image plane.
- mode
- None
- No tracking mode is enabled.
- Model
- Enables model tracking.
- VideoMarker
- Enables video marker tracking.
To set the current tracking mode to video marker
tracking:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetTrackingMode VideoMarker
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid, or PO_InvalidMipMapMode if the tracking mode is invalid.
