poIImagePlane SetShowTrackingMarker
Enables/disables the video tracking marker.
Imageplane_handle SetShowTrackingMarker show
HyperView Tcl Modify
This command sets the status of the tracking marker when video tracking has been enabled and calculated.
- show
- Set to True or False to indicate whether or not the video tracker should be drawn.
To draw the video tracker after calculating video tracking on an image
plane:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetShowTrackingMarker true
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid.
