poIImagePlane SetSyncModel
Sets the model being synchronized with the image plane video.
Imageplane_handle SetSyncModel model
HyperView Tcl Modify
This command sets the model being synchronized with the image plane.
- model
- The index of the model to be synchronized.
To set the sync model of an image plane with an index of 1 to a model with an index of
1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetSyncModel 1
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid, or HW_Error if the sync table is not successfully updated.
