2025
View new features for Altair HyperWorks 2025.
The Developer ribbon contains tools for automation and customization.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Create and edit outputs, add an analysis using the task wizard, check the model, and run the solver.
Use the Reports tool to view the report definitions of associated analysis tasks.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
