Change the Active or Export State of Entities
Set various states for entities in a model.
- Click from the menu bar.
In the Entity State Browser, toggle the Active/Export
options to control the state of entities.
Tip: Right-click on selected entities to view more options for selecting states.
Option Description Active The active/inactive state is a controllable state whereby the display of inactive entities will be turned off from the display in the graphics, the browsers, the display panel, and any panel entity collectors. It is designed to aid users who frequently work with large models and need be able to filter and reduce the number of available or visible entities. Inactive entities are still present within the model but are removed from access until they are made active again. Export The export/do not export state determines whether entities are exported when using the Custom export option in the Solver Export Options dialog. Note: This state does not have any effect on the All and Displayed export options.
All entities in the current model that have active and export states are shown in the browser at all times. Each entity is individually controlled via the browser, but all collected entities contained within a collector are subsequently set to the same state as the parent collector – control is not available at the individual collected entity level.
Changing the state of an assembly has two functions. First, it sets the state of that assembly directly. Second, it sets the state of all sub-assemblies, components and multibodies referenced by that assembly to the same state as the parent assembly.
Include files do not directly contain any states that can be controlled by the Entity State Browser. Operating on an include will, instead, operate on all supported entities that are referenced by that include.
