Manage Material Data
This chapter guides you how to launch and use the Authoring Tools in SMDC. It explains where to find these tools on the viewer page and the permissions you need to access them.
Accessing Authoring Tools
You will see which tools you can use based on your role and learn how to start managing and editing material data easily.
Click the launcher
button at the top left corner of the viewer page. -
Click Content Management Tools from the Manage Content menu.
Note: You need the required permissions to see Content Management Tools in your profile. Contact your organization Admin if you don’t have access.
Functions of Authoring Tools
Data Edit: A tool to add, delete, and edit material data sets such as single-point properties (Density, Young’s Modulus, Poisson’s Ratio), multi-point properties (Stress-Strain plots), associated features, and documents. You can also publish/unpublish material, compare versions, and restore previous versions.
Base Catalog: The master list of all material properties, plots, numerical models, material types, producers, providers, CAE cards, user roles, and permissions in SMDC.
Application Catalog: Is the SMDC front-end interface used to define and customize views on the main viewer page.
Catalog Data Transfer: Use this tool to back up the base and application catalog. You can restore catalog data by importing the backup zip file.
Material Data Transfer: Use this tool to back up material data in the database. You can restore material data by importing the backup zip file.
User: A tool to create new SMDC user accounts, assign roles, and set permissions for features and material data access.
Logs: This tool records all actions performed within the authoring tools, including date, time, and user information.
